lariat 7.3
- Joined
- Dec 2, 2012
- Messages
- 658
- Reaction score
- 0
Has anyone here done it? Is it worth the effort?
They're different widths than the 99-04 correct?
I'm trying to get them in a pair with all the needed stuff
Leaf spring mounts? It's going to coil spring lolLeaf spring mounts, gotta mount spring buckets and control arm mounts
05+ is widerSo is the 08 rear axle different than the 04-07? I know the 04 -06 is narrower than the 99 - 03.
Well yeah.Obviously... Remove leaf spring mounts.
Where did you get the link arms the truck is currently lifted around 5.5 inches and I want to keep it that way, trying to figure out if i should just get all stock then lift it or just try and save money by buying a lift used and not mess with the stock stuff
