06 drivers side sag, questions on 2012 blocks?
UnrepentantSinner
The factory blocks under my rear springs on this 06 f350 measure 3.5". It has about 1/2" of sag on the drivers side. I was looking around and heard that the 2011-2013 f350s have 4" blocks under the rear springs. Is this true? Would these blocks fit on the 06? Thanks
cfdeng7
CT
Please tell me you don't want to put a 4 inch block on just the driver side....
UnrepentantSinner
Ya, thinking of the block, the shim that ford sells for that problem is about 4 times the price of their block.
florida 6.0
florida
I cut down an old overload leaf and got a longer center pin for the spring and straightened mine out . I see a lot of leaning trucks around and it drives me nuts.
UnrepentantSinner
That's a good idea. How much did you cut it down? I think I'll give that a try this weekend
florida 6.0
florida
I found on laying around that was the right thickness and cut it an inch longer than my block. With a new center pin ( an allen bolt turned upside down) I had $3 in it . Just make sure your u bolts are long enough .
