06 Manual AC Not Working
ghostrider112
Manual AC in my F-250 does not work properly. If I want the AC to blow cold, it has to be set go max AC. It does not matter where the temperature knob is set, it could be on a heat setting and as long as the blend knob is on max AC it will blow cold. However, max AC is the only setting it will
Blow cold on. All other settings blow heat, again, no matter where the temperature knob is set. The blower settings work fine. It's just aggravating because it only blows ice cold, or hella hot. There is no in between. Any ideas?
Thanks guys
