08-10 axles
quadracer219
Northwest Indiana
So I got a opportunity to pick up 2008 axles and I was wondering what the general population thinks about these axles and swapping under a 00 f250??? Obviously a lot about the 05-07 axles, is there much of a difference?
the sway bar end links mount differently on the 08+ axles. other than that-i dont see much of a difference.
jimdawg185
Isnt the 08 front s dana 60 and the 00 a dana 50. Would be a good start to a coil over front end swap. Like stated above, the 05-07 is nearly identical.
quadracer219
Northwest Indiana
Basically that's what I'm doin, I'm gettin the front axle, hub to hub with the radius arms and brackets, coils and buckets, trac bar and bracket and sway bar and also gettin the rear axle. So as soon as I get em it's time to dig in and see if it'll work. Gonna try and do it in a weekend since this truck is my everyday driver.
bucklee00
I've been looking for a complete set of axles like this. What ballpark did you pay for them?
i've got a set of 05's i really need to get rid of to clear up space...
coil springs, front driveshaft, radius arms, steering gear, pitman arm, track bar... 108k on the setup. pm me if you want.
