08 Gauge pod ?s
94.5 Stroker
Lincoln, Nebraska
I know I will be asked why not just use an Edge CTS or something of that sort. But I like the look of the actual gauges. I know they have the single, dual, and triple pillar pods. Does anyone make any to go anywhere else? Has anyone tried the older SD overhead pods? Or should I just try something custom and put some kind of a pod on top of the dash? Pictures would be appreciated of any year of ideas.
Thanks Cody
AllanB
Mississippi
I'm pretty sure they make the overhead pods and the pillar gauge pods. I like the the old style look myself. IMO you get a little more security of mind having them. As where everything else goes through the OBD port to my knowledge.
Petro
Lincoln Nebraska
Check Glowshift, I think the last time i looked they had a few 08 style pods. Ive been planning on pillar gauges in mine also. The 7 color glowshift gauges in my 02 used to get the girls wet when id use the fade through the colors setting . . . . . I kind of miss that.
Petro
Lincoln Nebraska
HOLY F*CK they are pricey, you werent lien. Hell roughly 270 a gauge and then to add a relay is another 50.00. I do love the way they look but I dont value my 6.4 that much. Idk I might splurge and get some Isspros, im still trien to decide. The Glowshift Elite series gauges are cool looking, with the max recall and some other stuff.
AKHILF
Eagle River Alaska
Check out prosport gauges. I have them in mine. They are less than the speks and they are black when off have recall buttons on them and you can have them beep at you if you go over whatever you set you max/minimums to. You have to get the premiums in order to get a 60psi boost gauge but for all four of mine I'm right at $400
AllanB
Mississippi
Autometer Elite is a nice set of gauges also. Have a high and low set limit, then like a critical limit. If you hit that all the gauges start flashing. They also are a bit pricey. But not quite as bad.
AllanB
Mississippi
The gauge pods are a little scarce for different styles in the 08 and up. Takes so much $$$ to have custom ones made. Well, I say that but that was the custom job I was wanting. But I guess it takes a lot of time to create these things, and time is money.
94.5 Stroker
Lincoln, Nebraska
Allan do you have a custom pod in your truck?
AllanB
Mississippi
No, not yet. I am about to start working on one. But UT might take me a while before I get it done.
Petro
Lincoln Nebraska
Isspro... EV-2 with the warning lights...
P.m. with a price on the EV-2 gauges 0- 60 Boost psi, Trans Temp, and Pyro. If the price is half way decent Ill consider them over Glowshift. Do they make gauges to match the factory 08 gauges ?
