08 up sail panel/tweeder
1badpsd
lebanon,tn
Not exactly sure what its called but its the piece on the door that covers the mirror studs , anyways does anyone know if they will work in the older trucks if you have a pillar pod?
UNBROKEN
If you elongate the holes the sail panel clips into you can snap it if touching the door panel just like your original. It only needs to slide down about 1/4" or less.
Yes, they'll work with a pillar pod.
If you're thinking about wiring the tweeter in you need a newer door speaker also, IIRC that's where the capacitors are that separate the signal. If you just splic it into a speaker site somewhere something is gonna blow up.
SouthFlstrokin'
Couldn't you use aftermarket tweeters and crossovers in the sail panels?
1badpsd
lebanon,tn
Ive already got tweeters in the sail panels and they look good i just wanna do the newers ones so it appears factory
