Power Strokes
94-97 Aftermarket
1480 series u-joint
[QUOTE="m j, post: 623271, member: 9848"] pinion bearing preload is set with a crush sleeve, a cheap piece of tubing designed to collapse as you tighten the yoke until y ou get the correct preload on the bearings. stupid idea. in our trucks the diesel continues to crush the sleeve leaving your pinion gear bearings loose. on mine I found them so loose the shim under the pinion head, that should never see movement, worn to about half its thickness from spinning against the bearing. the Yukon 9" crush sleeve eliminator fits with just a little filing for the radius on our pinion. neat design that captures shims between two interlocking pieces. I was expecting a piece of tubing and some shims so was pleasantly surprized by what I recieved. think I paid under $35 for that part, small change when its well over $300 for the master install kit. [/QUOTE]
Latest: ghohouston
Yesterday at 6:06 PM
7.3 Aftermarket
Florida...
Latest: Mark Kovalsky
Wednesday at 10:22 AM
Southeast US
American made up-pipes?
Latest: Powerstroke Racer
Wednesday at 9:03 AM
7.3 Aftermarket
Georgia Roll Call
Latest: ju015dd
Tuesday at 7:03 AM
Southeast US
Ford 7.3 Passenger Bank Dead
Latest: Powerstroke Cowboy
Monday at 8:20 PM
7.3 Tech
fastersteve
LivinAnAdvntr
Power Strokes
94-97 Aftermarket
1480 series u-joint
