Truck came in, #2 contribution. Injector did not buzz. Replaced injector. Now buzzed but ran worse. Installed another injector, ran the same. Did a compression check, 430 PSI. Found faulty rockers, pushrods, bridges and lifters. Installed all new, now #2 is back to +18 on the short fuel trim.
the only thing I can think of is the cylinder is washed down and or the rings. but when I had the heads off, it looked fine, crosshatches were great...
any suggestions?
any suggestions?
