1980-1997 Big lift kit
BL4CKSUNSH1NE69
Simcoe Ontario Canada
I'm in a little town called Simcoe, Ontario. And I won't be running it at stock height ever. The idea is I'll also be swapping a 7.3 turbo into it too. Came with a 351 but I really don't want to put that back in.
NEVRNF
NW IL
Why not do a new style axle swap from a late model Superduty. Coil spring and 4 link on both ends? Much better ride than leafs. Look at OUO or Pure Performance or ICON factory front kit and a little modification for the front end. SHould be able to find axles pretty easy in the local salvage yard. A pair from a gasser with 4.30 gears and your are set for 40" tires.
