2008 tranny issue
Wingnut537
Hello all,
I have a 2008 F350 and am having a tranny issue. I was driving about 45mph and went to accelerate, truck downshifts and the felt like it jumped out gear. Now it will not engage in any gear fwd or rev. No codes are present and fluid temp appears to be normal. When reving it up in there are no unusual noises. Help please
Wingnut537
Yes, 4x4 park is holding it so that would eliminate the transfer case and the tranny output shaft.
Wingnut537
I should add... the truck is ******d, tuned with a ******** tune, turbo work, injectors, coolant filtration ect ect ect. And is turn 37inch tires. I am starting to think the input shaft has let go.....
Sent from my SM-N960U using Tapatalk
Any codes?
If you put a gauge in the test port in the side of the case, let us know what the pressures are.
Could be an intermediate shaft also
08Monster
I had an issue like this, tore the center out of one of the planetaries.
Sent from my Moto Z (2) using Tapatalk
Wingnut537
VFNqL2z
No input shaft speed leads me to believe that the input shaft has snapped at the TC. Tranny coming out today so we shall see
Edit.... I added a pic of the scanner screen but it doesn't seem to show. http://imgur.com/gallery/VFNqL2z
