2015 6.7 250 Lowering kit
Skiernan
Shawtown WI
Anyone know of any business or private company that is working on making a lowering kit for the 6.7's? not looking to slam all the way... but definitely would love to lower this truck down a bit to give it that street truck look and feel, thanks in advance everyone
Powerstroke Man 6.4
We do 4800# front springs and no rear block on the 6.4s to give it a nice lowered stance I don't know if its the same for 6.7's.
1BD9D7
I have a 2wd 2005 lowered with DJM suspension parts, they make basically the same thing for 2008+. The 3" drop in front is great but if anything I think it needs maybe 1" more of a drop, it's just not "quite" as low as I had pictured... Yours looks like a 4x4 (if so then the djm parts do not work) I am interested in knowing how much a 4x4 can be lowered.
Skiernan
Shawtown WI
ill look into the kits and see if i can find a similar kit and ask around to make sure it can work, thanks everyone for the help
The biggest thing to watch out for on the 4wd trucks is the pumpkin contacting other parts. If you go low enough you will have to run bump stops to keep if from contacting stuff all of the time not just for emergency purposes like hitting a very big bump, small cars or motocross jumps.
Athens, IL
We have lowered quite a few of the 4wd. If you would like some ideas or prices we can help. Here are the last two of my personal truck that are lowered. The Dually is low. Only has 31" tires.
dcswetman
Girard, GA
What size tires are on your srw? Buying tires here soon and im goin to pull the block and install springs doing that process
Athens, IL
worm
central IL
where are you guys getting the 4400# springs? if you go that low do the bumpstops need trimmed?
