2016 f250 wheel and tire combo
wes1227
Orange tx
I'm going to be purchasing a new f250CC, I was wanting a leveling kit and to run 35s with 20" lethal. I absolutely want no rubbing at full lock while going forward or reverse, and still be able to have travel. Is this possible and if so what backspacing etc.
thanks for the help in advance...
No one can answer that without knowing the offset. Also, there are a bunch of threads on this if you browse the suspension forum
wes1227
Orange tx
i just want to get this right because some of my truck before dont rub going forward but do in reverse but i still want good travel.
atthelake27
Oklahoma
Need to know the wheel width and offset like Sootie said... If your running a 20x9 or a 20x10 with a zero or positive offset then you'd be fine with a leveling kit. If you go with a 20x10 with a big negative offset its going to rub.
