oneturboforme
- Joined
- Sep 12, 2011
- Messages
- 1,040
- Reaction score
- 0
i need this thing to someone who will actually ride it.. The motor was built by SLP it is not bored it is ported and the head has there mill in it.. cards are bored and have a divided plate installed in them.. welded crank with wisco piston boysen rad valves, has the gas operated power valves, two sets of twin pipes jaws d series and slp twins.. the head that is on there is a speedwerx mono head but it is cut by slp, has a timing key in it also... The case got drilled so you can run premix, engine torque ARM, upgraded clutches off of a newer m series, titanium jack shaft and drive shaft with anti ratchets, has a belt drive that was made by white lighting performance...drop and roll, wilwood brake and chromemolly brake motor, new belly pans with airvents in the sides, nice aluminum mesh hood, 3" extended forward mount chromemoly post .. 6" pivot risors, fly fat bars.. throttle block, clear tank, good boss flat top (usa), van amburg boondocker tunnel, fabcraft chromemoly a arms 39" stance, float shocks all the way around, fabcraft spindles, powder pro skis, m series 162 skid with big wheel(only 2 In center) chromemoly linkage in the rear skid.. camoplast 162x16.. also has almost all the stock parts and I will throw in a boss noss kit.
i live in utah the sled at my parents in washington im willing to deliver anywhere in between 3500 or trade for a newer 450 bike or something i will use. text or call kyle 5094063055 i have a few more pics i can text ya
