22x14?????
1badpsd
lebanon,tn
Whats the minimum lift id need to clear 22x14s with 325/50/22 on an 01 F-350? I dont mind trimming my fender liner but dont wanna cut my bumper/fender
jngreen
IN
If my tire size calculator is correct, the tire size is a 34.8x12.8. I ran a 35x12.50 on my 2000, on a 12" wide rim, with a 3.5" BDS hanger kit and factory V codes. The tires still rubbed the liners a little after pulling them back with zip ties.
In your case I would say you need at least a 4" lift, or 3.5 inch hanger kit with x-code springs.
Mink would be able to help.
1badpsd
lebanon,tn
Ok thanks i have 12 wides now with 33 12.50s with about 3.5 inch lift in the front and they dont rub at all. I dont mind trimming the liners but if i did another 1-1 5 inches woulf i clear the bumper and fender?
jngreen
IN
Don't know for sure, I have never ran a 22 by 14" wheel on basically 35" tires. I would have to guess that 4.5 to 5" would be enough.
Josh@DirtyDiesels
PA
I know there's a guy on here 1sicpsd I think. Said he runs 4.5 and 22x14 w/ 35x12.50. I think it'll take 4.5-6" lift to clear
MINK
London,OH
the 325 is a bigger tire than the 35x12.50....for it to "clear" you will want 6" ....4" and trimming will work also.
