305/60r18 on 02.
dsberman94
Pennsylvania
Ok no luck on another forum so I'm gonna try it over here and hope for an answer that helps. I got a set of 08 18s and I've seen them with 305/60's on my buddies truck. I like the amount that they stick out on his truck and I want to know if they will fit on mine with a 2.5 inch wheel spacer. I found some of this size spacer but only in aluminum and they warranty the spacer and anything if the spacer breaks and causes damage but does anyone know whereby could maybe find some steel ones? Also the reason I'm worried about them fitting is my truck is not getting lifted. It will be getting leveled but not lifted. However I want these wheels on ASAP so I want to know if the tires will rub on a full turn. If it's just gonna be a little rub at a full hard turn I won't mind but if it's gonna be terrible I'll have to either buy thinner tires or level it first. Thanks in advance
