33x12.50 on stock 08 wheels?
Dustball8504
Everett, PA
Will 33x12.50 tires fit stock 20 inch 08 wheels and will they rub on a F-250 at stock height? I really don't want to lift the truck at all.
ZacPSD60
Spring, TX
Yes they will fit fine. The stock tires on those wheels are 34.5" so you shouldn't have a problem at all.
TripleE44
Keller, TX
There's a few guys running 35x12.50s stock with minimal rubbing. I'd say they'd more than likely fit.
Jeff@Spartan
Georgia
If it rubs anywhere, it will rub on the radius arms. That's a short tire. Why not go with a 35" tire? Those 33's will measure less than 33" mounted.
Daryl@TDP
Chesapeake, VA
They won't rub at all. My buddy had his at stock height with 20x12s and 33 toyo mts and then put the 33s on his factory 20s. No rub with either set-up. No leveling kit what so ever.
Dieselroller
baytown,tx
Went with a general grabber a/t and really love them! They aren't too expensive and last with a good ride. Same tread as a BFG A/T
TripleE44
Keller, TX
The rub that we're talking here is just grazing the radius arm at full lock. It does no damage to anything other than the paint on the radius arm. Makes no noise and it's something that if you were that worried you could just be sure not to turn that far. I wouldn't go with a skinnier tire for that.
Dustball8504
Everett, PA
Right, I had 35x12.50s on my 04 with just a leveling kit and it rubbed the leaf springs hard at full lock and would shake the truck lol. It wouldn't bother me if it rubbed a little a full lock and made no noise though.
TripleE44
Keller, TX
My truck rubbed the radius arms on a 2.5'' lift and 325/65R20s just because of the width. The radius arm rubbing was so un-noticeable that I didn't even know it was happening until I was under the truck cleaning and saw it.
