38r in a obs
tsmith7.3
FL
what would i need and has anyone on here done this? just looking for some recomendations and help as to what would be required to make this possible??!!
Magnum PD
VA
Your gonna need the newer style Super Duty turbo pedistal, up pipes, 3" intake manifolds,
tsmith7.3
FL
I am going to run a intercooler but just didn't know about the manifolds mainly and if my down pipe would work also going to buy the non ebpv pedestal
300000 and counting
Ohio
What's done to the truck, i think it would be more beneficial to run a D66 drop in or get a t4 setup and an s366. I wouldn't waste time and money on a 38r
tsmith7.3
FL
That was my next question if it was worth it over a s366? I don't want to do a d66 I feel I'd be much happier with a s300 series and its stock now. A e-fuel kit is coming soon.
tsmith7.3
FL
Also if I buy irates t-4 kit with turbo what else would I need besides an intercooler and any recommendations on a intercooler to run? Stock sd or aftermarket?
97f350stroker
Burgettstown pa
I recommend going to a t4 set up if you're planning on getting that far into it anyway. That way you are open to more options down the road to injector changes or whatever else you may want. A stock sd aluminum end intercooler is the best choice imo. Easy to mount and usually found pretty cheap. I just put a 6.0 intercooler in mine and it was a little more tricky on the install than the other ones I have done with the 7.3 cooler.
