3x3 led fog mounts? Not rigid
nick0360
methuen ma
Anybody sell or have brackets that will mount a 3x3x3 led cube in fog lights location, I heard the rigid bracket won't work but looks lights they would any input would be great thanks
powerstrokedkid87
New Jersey
pm imotionjosh he has a pretty nice set up, looks like it should work with the 3x3s. We did a set up on an 11, and im waiting on my set up for the red truck.
Wrecker
I'm running inmotionjosh's kit with Aurora LED cubes, they are exactly like a Rigid D2. The mounting bracket itself works perfectly, most of the off brand lights have the same mounts as Rigid, but the wiring is opposite of Rigid's. Meaning the wiring harness adapters for a Rigid light have the positive and negative wire on a certain side of the directional plug, on my Aurora lights the positive and negative are opposite and you can't just plug it in backwards cause the connectors only plug in one direction. All you need to do then is cut your harness adaptor two wires in half, splice the neg to pos and pos to neg and everything will now plug in correctly and have the correct polarity.:thumbsup:
nick0360
methuen ma
Ya I'm not worried about wiring I got digi dioldes cubes and they do look the same I talk to josh and he said they won't work but I'm gonna give them a shot
South Florida
I used to have my own light brackets that worked on all 6.7 trucks. Rigid got smart and created 1 bracket that works for all fog lights on 99-15 trucks :doh::eek:wned:
My brackets did allow you to use the alternate brand of lights but these new ones are rigid specific. I will sell them to whoever thinks they can make them work but take my warning, they won't work....
