4.30 gears on truck with 38" tires
Coueshunter
Gilbert, Az
Anyone running the factory ford gears? Thinking of picking up a set to swap on my truck when adding 38's. Anyone do this?
Dzchey21
wyoming
Rpm wasn't too high at 80-85mph?
our service trucks run 2500 rpm at 75 and they last plenty long, I don't think these things have all the cavitation and water pump issues the 6.4s had
Profuzz
4:30 made 06 6.0 feel thousands of pounds lighter my 15 tow boss came / 4:30 and with stock 245's still not bad at highway speeds !
JRLott
TX
You mean the thread talking only about part numbers and not the actual drive ability with 38" tires
Yes that one...obviously some have been doing it, so the answer to your question would be yes. Since you never actually asked about the drivability. LOL
Just messin with ya. I've been trying to find the thread another guy posted about going from 3.31 to the 4.30s. I thought it was a big friggin jump and said I'd go with 4.10, but some one posted that they went with the 4.30s and loved it, especially due to the additional rotating mass. They also said it wasn't that bad on the highway and posted their RPM at highway speeds, and I think they were in the 80-85 mph range. Been trying to find it, but my search has been fruitless thus far.
Coueshunter
Gilbert, Az
I suck at searching. My keywords never work.
430s are a little better on the gear scale then stock but not a crazy difference. I think it will be good enough. I tow a lot but like lifted trucks....
STROKERBO
St. Clair Shores, Michigan
I found out by experience that the 4:30's will actually give you less fuel mileage than the 4:56's with 38 inch tires.
But I do have a nice set of Yukon 4:30 rear gears for $100.00 plus the shipping if you are interested.
Coueshunter
Gilbert, Az
Is that on an 11+!though
jimmystoys
Surrey, BC
I have stock gears with my 40". Maybe a little slower off the line but I have S*****N to take care of that. What I like is the cruising at 70-80 mph.....1500-1800rpm. No motor sound just a bit of tire howl, I'm enjoying that.
T_W6.7
Montana
4:30's with 37''s is what I went with, actually puts you a little above stock rpm's at 75-80, I would caution against 4:56's or higher in an 11+ seems like you'd be encroaching on the 3000rpm while cruising at 80 pretty quick. As far as part numbers I don't know, call ford and give them your vin and they'll hook you up with everything you need at a price not that much different than yukon or nitro
Jrs6.7
I was the one that posted the thread about going from 3.31 to 4.30 with factory e locker. I don't regret it at the least bit. Drivability is great 70 mph puts me at about 19xx rpm. Truck has been running great and got about 5k miles on the gear swap. The extra rpm I feel helped a bit for towing as well as it keeps boost up.
NCSU dirt man
Ft. Bragg, NC
anybody know how to read/understand the numbers/codes to determine which gear ratio you have? I lost the window sticker at some point in my glovebox and wasn't sure without asking for an oasis report. the truck is a 2011 F350 SRW CCSB Lariat FX4 w/ Ultimate package
