44mm offset Fuel Throttles and 37's
jdjd
Ran into a good deal on a set of 20x12 Fuel Throttle wheels and Toyo MT 37x13.50 tires that have 44mm offset and 4.75 backspacing.This is for a 2003 F250 longed with around 7 inches of lift. Icon hanger lift and a mini spring pack in the front.Will I have rubbing issues on the leaf springs or the fenders or bumper with the 44mm offset?Anybody run this same combination? I would like know before I would buy them. Thanks... Photos would be great?
pjtamu12
I'm totally shooting in the dark here, but with a -44 I think that you would be fine. You may have to trim some in the front at full lock or something like that. But with 7" I think you should be OK. Probably no issue in the back with the leaf springs.
