4R100 build
brian89
Penisylvania
I'm thinking about rebuilding my 4r100 myself, buying a rebuild kit, converter, and deep pan and doing it myself, its been f-ed up for over a year and a half now and I finally have a little money and I have decide I would like to try it myself, never been inside an automatic trans and not really a good understanding of how it really works, anybody who has tried it or is very successful at it please either try to talk me out of it or tell me with the right tools i will be fine, i have a book/manual that i am going to read cover to cover as well, and what rebuild kit and converter would y'all recommend? any little bit of advice, warnings anything is helpful
Justin@DP-Tuner
Might be doing this in the future also. I'm sure a good guy to contact on here is Mark Kovalsky. He is the 4R100 whiz. He is also a former Ford transmission engineer I believe.
907DAVE
AK
Here's you special tools:
Two slide hammers with threaded adapters to pull the pump.
A few pieces of flat stock with some all thread to use to compress the intermediate return spring to remove the retainer.
A chunk of exhaust pipe and a vice or press to compress the coast/ direct clutch spring.
Two pieces of looped bailing wire to drop in the forward clutch assembly.
And to align the pump half's, flip the pump into your empty case - upside down - and torque your bolts.
Ohh, and a ATSG manual!
If you can follow the directions in the book and have patience there is no reason you cannot do this yourself!!!!
Justin@DP-Tuner
Great info, thanks! I am assuming you have done this before? If so, how did/is yours holding up?
brian89
Penisylvania
home made special tools, i like it, and yea whats the rebuild kits yall have been using and how well are they holding up? and my atsg manual got here today
907DAVE
AK
Been holding up fine to many years of abuse and heavy towing. The last few years the truck has probably been around the +600HP mark. I am about to find out how it likes 450/400's....:D
Justin@DP-Tuner
That's awesome! :D What rebuild kit did you use?
Bigsexy
Lochbuie, co
The only down side you can mod the pumps as bts and other builders can, unless you know a trans guy. Best thing to do is buy the book from ford and it has a step by step rebuild book. I did mine with my buddy who builds diesel trans for a living. Other then that the 4r100 isn't to bad. Mine has close 10k and not a problem. My buddy who's a trans guy got me all the parts. I also got the stallion t.c. just because that's what bts uses. my trans guy was friends with Brian at bts before he moved out here. It does what I need it to.
brian89
Penisylvania
I'm pretty well set on a Stallion tc, Suncoast rebuild kit and valve body, mag-tech deep pan, 6.0 trans cooler, and still thinking about a controller
brian89
Penisylvania
Bring back an old thread but i finally got around to the rebuild, stuck on the intermediate return spring install, going to get a couple pieces of flat stock tomorrow, after that i will be rebuilding the solenoids and the front pump, other than that, cake walk
OSCS
Houston, TX
Who makes a rebuild kit to hold 5-600? I have a precision TQ converter upgraded pump and VB already I have a core and want to build to hold 5-600 minus the parts I already have
