Force2354
i thought the 5r110 was a great transmission, why do some guys have 4r100s in there trucks?
as of now, i believe the shifter light doesnt work, and it throws a CEL. but i think it drives just fine. it has to have a standalone TCM. unless youre going for huge power i think just a really well built 5R should be sufficient.
I wouldn't look at a 4R swap as a cheaper alternative. The 4R swap was designed with all out drag racing in mind. You have no PRNDL stuff, and it throws codes. I know there is supposed to be a box in the works for it, but it isn't finished yet. The biggest pro to the 4R is the way it shifts, there is less physical limitation with the quickness of the shift.
I'm not sold on the 4R being any more reliable than the 5R at this point. The 4R's have had issues, same as the 5R's.
