5.4L Coil....HELP!!!
08PowerSmoke
Raleigh NC
I have been reading that everyone is using 5.4L coils and removing the rear blocks for a better ride and to lower thier trucks.....So I went to pick some up at the Ford place. My question is what part number is everyone running.....
5C3Z-5310-FA Which is a 4800lb spring
5C3Z-5310-GA Which is a 4400lb spring
Currently I have a 5C3Z-5310-EA that is a 5200lb spring. ANY HELP WOULD BE APPRECIATED!!!
dstryr
Gilroy CA
I will have 5.4 coil springs for sale this weekend if anyone wants them. My carli system is going on...
08PowerSmoke
Raleigh NC
OK got my springs in and went to get them put on......
NOW problem is U bolts dont have enough thread in them.....Tech says I have to get in shorter bolts....DID ANY ONE ELSE RUN INTO THIS????
OneStockQuik6.0
How much shorter do the u bolts have to be, Do you guys think that a set from a non 4x4 truck will work?
Tree Trimmer
do the math.
how much shorter are you making the rear end? thats how much shorter they need to be.
or, put the entire kit on, put your existing bolts in, see how much to long they are, then go get them so you know for sure.
OneStockQuik6.0
Does anyone have any pictures of their truck with the 4800lb in front and no rear block or fatty leaf in the rear,and same tire size all the way around?
dstryr
Gilroy CA
