58V FICM Software Incompatible code
IntrnlDslDriver
Verona,Va
I have a 2003 6.0 that I put a 58v FICM on and it cleaned the slight miss up on it. Here recently I put a Oil Cooler on the truck and after I put it back together the truck has a PO263 code. Would this be throwing this code if a injector connecting was bad or got bent on reinstall after the oil cooler replacement? It was not missing before the oil cooler was replaced..
Mdub707
Mohawk NY
It's for cylinder #1, front of the motor, passenger side. Just make sure the injector clip is pushed on all the way.
ZacPSD60
Spring, TX
Could be, and from what I've seen usually is, just a bad connection. If the connection and wiring checks out, it could be a bad injector. Not likely, but definitely possible.
