5r110 swap to a 6 speed
Redneck6.0L
has anyone done one, whats all involved, trans, trans wiring harness, clutch pedal, gear shifter:lookaround: i heard something about the hump on the floor needs to be modded
co04cobra
WV
Hump is different (you can make either work). Also, the adapter plate on the back of the motor is different, and pcm. As well as the other stuff you listed.
