6.0 electric fans
dohcter
What's a person do when deleting the fan clutch, when electric fans are installed? Truck is real doggy without the clutch plugged in. Thanks
strokin6L
Springville NY
I ran them for a while with zero issues. just unscrew the factory fan and wire up the electric ones. pretty simple. I went with the flex-a-lite 7.3 powerstroke kit. There's a VSC(variable speed controller) with the kit and a temp probe that gets installed into the radiator. You can have them come on at a certain temp.
ford rules
Dosent the fan run differently if the truck has ac. Like if the ac is on it will kick the fan on even at times it dosent need to be?
dohcter
This truck has the flex a lite fans already installed. But is really laggy with the fan clutch unplugged. Truck is a 05
dohcter
Thought I updated this..problem turned out to be a bad abs module not always givin a good speedo signal to the PCM. Truck has been going good for a few weeks now. Thanks for the help.
Zmann
thanks for the update
cause the fan clutch unplugged thing made no sense to Me
TheReelMuhcoy
New Jersey
Anyone else have any other suggestions of an electric fan setup for this? I would be interested in doing something like this for my truck for accessibility reasons. Anyone done their own DIY kit?
Zmann
Aftermarket can't make a kit good enough for towing
so a DIY kit may be a trick
Cutting-Edge Diesel
Newkirk, OK
just installed another flexalite kit on my other 6.0 and it does great. Love this mod. Doesnt tow heavy tho. towed about 8-9k the other day. 99* never got above 200. stayed around 194 most of the time. that was even in the race tune. Before it would over heat in about 7 miles (slow driving dirt roads and fan clutch wasnt working)
Zmann
but your the only poster I ever see who had no problems with the Electric fans
and towing
strokin6L
Springville NY
I am? Ellerton towed Tylers truck to DPC a handfull of years ago with his old blue crewcab race truck with the flex-a-lite setup through the mountains of Colorado weighing probably 14k with tylers truck and trailer with zero issues in hot weather. There's many others doing it without a problem.
97BambiBasherPSD
Edinboro, PA
I'm lookin into this myself to clean up my engine bay and to make changing parts easier. Anyone got a link to the fans?
Sent from my Pear phone using Tapatalk
simonton6.4
Monroe,Ga
Has anyone noticed a performance difference I know on gas jobs if you do a efan its a pretty noticeable increase or at least the ones I have done before?
