6.0 ficm bolts/ air filter clips
MNStroker316
Minnesota
I am looking for a couple ficm bolts (two specifically) and 2-3 of the latch clips that hold the air cleaner assembly together!
Thanks
78f100
Bonifay FL
I think he means the nuts, older style 10mm head with a concave like a lug nut. Fits ones without the vibration damper rubber on the ficm. A nut and washer will work just fine if your ficm bracket has studs, if not m8 bolts fit. There are 4 different ficm brackets that I know of on these trucks, so maybe take a pic of what you have, I'm sure I have several. As far as the clamps any shop who does any sort of diesel performance probably has some from old airboxes they have removed. I usually have several in my tool box I like to keep them for when trucks come in missing one. If you only have 2 put them on the back side of the filter housing it's the most important, the front 2 only hold the fender scoop on until you get new ones. Ford dealer should have both, I'm a parts hoarder...lol pm me if you can't get any elsewhere.
MNStroker316
Minnesota
Sorry for the late reply. I didn't know there were so many different styles for the ficm brackets. I'll post some pics when I get a chance. But yes you're correct about what I'm looking for. The 10mm nuts with the concave shape.
