6.0 haze at idle with aftermarket injectors
weekendwarriorfsw32
Central California
When ever I start up my 6.0 with 190/75 Full force injectors it hazes like a mofo. I got a video of it was just wondering if it had to do with my Innovative tuning or is there something else I am missing here. The truck has a air dog 165, regulated return, pmax with RDP billet wheel. I'll post a vid of what it looks like at idle in the morning. Just hoping it more tuning related.
http://www.youtube.com/watch?v=z6VQ1lyfb9s&list=UUamKcSV06A8Z5aW_GB5cmtQ
JGman141
Ohio
My injectors don't even haze that bad, it has to be tune related
Josh@DirtyDiesels
PA
that looks like it might even haze more than my 305/150's with IDP tuning...
here's an old idle vid. Can BARELY see a haze. Don't mind the lope that was a combo of the tune that was in there mixed with the ficm tune it had in it then. Idles much smoother now.
https://www.youtube.com/watch?v=dZYFQr0kzX4
strokin6L
Springville NY
I have Casserly 190/75's also...and they haze a little. Not as bad as yours tho. Back off some fuel at idle and should be better.
Ruger5901
I have 165/100s from mpd. Innovative accidentally wrote my tunes for 175/100s. I called back and they said it doesn't matter it would help clear up smoke. My truck hazes at idle too. If I get tuning fixed do you think it would help?
pipeliner
Ive got 190/100's it hazes on some tunes and some tunes it doesnt. Just have your tuner pull fuel at idle.
motoxracer42
it would be the same amount of fuel at idle. if its tuned for 100% nozzles its fine. now if you have trouble on the top end like dropping icp bad or shuddering I would retune for a smaller file. im pretty sure im the only one who has or ever will encounter that issure though.
imelmo
My 205/100's don't even haze that bad at start up. How cold is it where you're at in the mornings?
Gearhead
I second that.... the nozzle is the main factor where idle is concerned.
motoxracer42
after watching the vid I would look for contribution codes. sounds like you got a little miss going on. could just be the vid though. nozzles that are extrude honed too much will smoke pretty like that
weekendwarriorfsw32
Central California
I think the miss is a mix of normal tuning and my FICM tune, I am going to put the FICM to stock and then try my new gearhead tune tonight and see how it does.
