6.0 manual to 6.4?
HOOV3R
Central PA
Yes, the zf6 will fit the 6.4. The 6.4 trans tunnel will need modified, so it isn't really a direct swap.
co04cobra
WV
If its going from auto to manual the rear engine covers are different on the 6.0 and 6.4.
MorganY
college station, tx
Youre in for a ride. Witnessed a swap done in a 6.4. A member, Brooksfruge did it to his DD.
Rear covers, driveshafts, trans tunnel, pcms and body harnesses different. Im sure I have left out a few things
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
ROLLING THUNDER
hillsboro,ohio
Im well aware of the changes , and even more installing it in a 02 chassis. already have the manual pcm ,I believe my trans tunnel will be fine, and for the drive shaft im getting a one piece made for the truck.
