6.0 T4 oil drain
Mdub707
Mohawk NY
What are you using? Something like Cutting Edge's pipes that have the mounts built in? Probably braided drain line would work.
strokin6L
Springville NY
You can't use the factory drain tube...it just slides in and is sealed with a o-ring. Where as a non vgt turbo drain line is bolted to the turbo and is sealed with a gasket. MPD also makes them for their non vgt setups.
loboost
You can modify the bottom side of the return tube..
but you can't use it as it is.
i use a modified stock drain.
Do you use a hard line adapter ?
Cutting-Edge Diesel
Newkirk, OK
this is my drain.
