6.0 with a Powerglide?
imelmo
So now that the donor truck is here for the Fordota, I'm trying to get my ducks more in a row. I was initially going to run a 4R behind the 6.0 but the more I think about it the more I wonder if I can put a Powerglide back there instead. With the huge tires and 2.91 gears that are in the rear I should have plenty of rpm I would think. Plus the Powerglide would be significantly lighter I imagine. Not to mention parts availability/cost and less shifts to worry about.
So if I were to attempt this, where would I start?
Cutting-Edge Diesel
Newkirk, OK
I would go th400 over a glide for the extra gear but I think you will miss lock up a lot. Problem with a non lock up is you have to run a low stall to get the efficiency down the track but it hurts you on the line to spool your chargers. It's a constant battle. If you can get a lock up 400 (im not sure if you can) that would be awesome!
But the advantage to a 4R is it bolts right up and lock up with overdrive.
Dzchey21
wyoming
I think they do make a lock up glide but its pretty pricy. From what I have seen the TH400 is the way to go.
imelmo
Yeah I checked and Hughes and ATI both carry a lockup Powerglide. The Hughes one didn't list a price but the ATI one with all the bells and whistles was $11k. Gonna check on the TH400s now to see what they have. Thanks for the input.
78f100
Bonifay FL
Several moths ago when I was at suncoast they mentioned doing a th400 and a glide. I tried calling them a few times today to find out some info but had issues with my cell. I will call Blake tomorrow to see how far they are along. A th400 would be great but a glide in something as light as your truck I think would be awesome with lockup. I have been studying this pretty hard for a month or so also.
imelmo
Cool. I'm gonna wait 'til I get a little closer to that side of the project and then call them.
DZL JIM
North East Ohio
I run a basic built Powerglide behind the 7.3 in my Altered, the set-up works fine. We built the adapter ourselves and I had a custom torque converter built for it.
The only benefit I can see running a turbo 400 would be an extra gear to get a heavier vehicle moving. Both 1:1 in high.
Glides are super simple to work on and rebuild if needed.
imelmo
Pics of your altered? Didn't know you had one.
DZL JIM
North East Ohio
As you well know how it goes....We started it over 9 years ago. The family grew, then the business grew, and it got pushed into the corner of the shop. I started working on it again in March and just hit the track finally 2 weekends ago. Still working the bugs out and fixing this and that.
Best ET so far was 10.40 last night with crappy launch and computer/tuning issues.
Every run we learn something new, lots left in it for sure.
The car weighs 2550# with me in it (I know, crazy heavy for an Altered, but it was scratch built around a 7.3 block to handle the huge slug.) Any idea what the Fordota will weigh in at?
Sorry, there are no pics online yet, just haven't had time.
