6.4 auto to zf6
nikotmt
I have a fully loaded 2008 lariat in the process of a transmission swap and need help understanding the engine computer part number differences. what engine ecm would work. seeing that my current ecm is an auto what electronically needs to be flashed. i am also looking for information about deleting the transmission computer and what harnesses are needed to complete the swap any help would be greatly appreciated :fustrate: thanks in advance
Stroked777
Casper, Wyoming
I think you just need to have the engine computer to be flashed to that of a manual computer. I don't think you physically need to swap the computer it's self.
Also subbing, I was considering this my self to do to my truck
Stroked777
Casper, Wyoming
nikotmt
thanks i had seen that thread earlier and it seems ike he ended up having issues wasnt quite sure what he ended up doing sent him a message no reply thanks i'll keep you updated thanks
Big Angry Hillbilly
I'm fairly certain they will accept the same software. The problem lies in when flashing the software to the PCM with IDS, the software will ask for the VIN, then download the ASBUILT for that VIN from the master database. I haven't tried to blank path an automatic PCM to manual, but I suspect it will give you a software incompatibility error, unless you manually download the asbuilt and modify it accordingly.
Hope this helps.
nikotmt
i got a nother question i got a automatic t-case where will the vss signal come from there is two connectors on the t-case one on the electric motor itself and a 6 pin above the housing of the motor is this possiby a speed sensor and a position sensor there is only one sensor on the zf6 that is reverse.????
nikotmt
thanks i wasnt sure appreciate the help one more thing i need a vin off a 2008 6.4 manual trans truck so i can pull up the as-built ecm software any one help me out
thanks in advance
nikotmt
IF i can supply my vin can anyone modify the as-built data for me to be configured as a manual seeing that they did not offer a lariat with a manual trans. that is all i need to get this truck running. thanks
nikotmt
i need a wiring diagram for a manual all i can find is the automatics i need to wire up my clutch pedal position sensor any help???
Super08Duty
College Station, TX
He had a cut CAN wire which caused a minor problem. It's his current daily driver right now. He doesn't get on the forums very much.
nikotmt
thanks in advance
It appears to me that I may have the same problem ford cannot communicate with my truck at all. Any help would be appreciated thanks
