6.4 build
6.4_miller
North carolina
I have a 09 f250 with elite diesel atmosphere 76mm drop in turbo. 30% injectors.
I'm going to be selling the elite diesel turbo when I go single turbo.
I'm looking to buy a s472 or s475 in good condition.
I'm also looking to buy a dual fueler setup.
Black AOD
Ohio
Welcome to the Army. Why the switch to the single turbo?
If I were you I'd do Midwest Diesels dual fueler setup. They are a vendor on here and both Jared Rice and Morgan Primm who both work there are very active on this forum.
6.4_miller
North carolina
If anyone is looking to buy my old twin setup with drop in 76mm atmosphere elite diesel turbo. Let me know. I'm around the Asheville NC area
Unless you are going for all out power, the factory style compounds outweigh a single in many many ways.
01pwrstkr
Polk County NC
What are you asking for it? Pm if you'd like. I'm right down the mtn from you in Polk County
Sent from my SM-N920R4 using Tapatalk
Black AOD
Ohio
Agreed with Ron. There are people successfully running a single in many ways on 6.4's but the VGT compound setup is really hard to dislike IMO. I'v watched workstock 59/76 elite compounds with a dual fueler kit and 60% injectors make over 800 on fuel and go 11 seconds all day long and the drivability they have is unmatched compared to say a single s468 or s472 with the same fuel setup. The compounds will light faster, be better on the street and be more fun all the way around in general. That being said, Mike Corsilli from MPD has done some really crazy stuff with his single s476 6.4 truck and Taylor Overcash has one of the fastest 6.4 race trucks ever using a single s476 and now a single s480. Pulling trucks also tend to use single turbos but I believe that to be for lots of top end power.
I honestly believe if you added a 59mm VGT HP turbo from elite to make your setup the Jr. High Powers and add a dual fueler, you would make around 750-ish HP and it would be everything you want it to be. Hopefully your motor and trans have been modified to live with that amount of HP.
