6.4 turbo boost? Few questions
Karen2.0
Hey guys, my 09 stroker, has been weird lately, it likes cruising at around 20psi doing about 90kmish, it used to be around 5-10, I thought it jus might be my tune (210 tow performance) so I tried couple other tunes, and even stock, same thing
My fuel mileage has been terrible aswell 300km to this tank makes sense more air, more fuel, Thanks if someone can tell me if this normal? Or I got something going on I need to get looked at,
Thanks guys!
mclean
Fort McMurray, AB, Canada
I'm having similar issues, I know my vgt actuator was stuck at one point so I hit it a couple times and that sorted that issue but I am still 5-10psi higher than normal.
My next option is to check my air filter, after that, not really to sure
Karen2.0
I had about a hour drive, the other on the highway, and it would go back n fourth from normal to what I think is way over boosting, on a flat road, no wind, would that be to do with my actuator?
I would replace the ebp sensor and see what happens.
Is the truck modded at all?
Karen2.0
I have a spartan tuner, dpf delete, afe pro gaurd 7, and airdog, I got a few other things but I doubt they would effect it,
Where would I find this sensor?
Thanks for the reply!
TD-5
British Columbia Canada
#6 in the attached picture
forcefed6.4ford
Medicine Hat... Again
Any codes?
I was over boosting HUGE last week when it got really cold after a long warm spell. I had some frost on my MAP sensor. I made sure I plugged the truck in over night and allowed the block heater to thaw everything out and the issue went away.
Karen2.0
Mine was doing it in the summer to, I'm gonna try and clean it tmr, if that don't work I'll get a new one, thanks guys! This is a great forum!
forcefed6.4ford
The sensor can be cleaned as well as he tube. Compressed air with some break clean for the tube. Air and a wire brush to clean the sensor head. If that doesnt solve it, just buy a new sensor.
7.3powerstroke00
Brownwood
I would try cleaning the tube and ebp sensor like said, my 09 stopped up and was really Smokey and laggy. Cleaned the tube and sensor, fixed it...
Karen2.0
I cleaned the sensor I couldn't do a tube I didn't have a wire brush on hand, all I had was a tips, that thing was plugged real bad! But still no difference not even a slightly, would the tube also effect it that much? And that don't look fun to take off n clean... Lol
duddy
sloshkosh wi
Not sure yet, have not pulled mine off. I blew mine out on the truck, however I already removed the egr coolers so I was not worried about **** being in the pipe.
