I have one with a vibration.
Sometimes at idle it will shake the truck, push the clutch pedal enough to slip the discs and it will quiet down.
Are you sure when you installed the flywheel that the crank adapter and flywheel seated properly? Mine was a pretty snug fit and it took some work to get it so it would sit flat and tight to each other.
