6.4L Injector Timing
Sixfoh
Ill try to keep this quick and simply as Im sure this topic has been brought up before and will likely ruffle some feathers. On the matter of 6.4 injector timing measured in degrees before top dead center, what kind of figures do you guys see? Would like to know your idle figure, maybe a couple mid rpm timing events and what figure you see when giving it the onion. Feel free to add information like the tune you might be running, dyno hp/torque and and information that pertains to what you did to make your truck run like it does. Lastly give your input on what safe levels of timing are, whether its based on what youve heard or experienced first hand.
