6.4l Single Turbo Kit $985, $1195 w/S366
Apcdiesel
Fort Myers Fl
Hey guys up for sale I have a 6.4l Single turbo kit. Turbo kit will come with all oil lines included feed and drain, all pipes necessary to install to your factory up pipes. Looking to get 985 for the kit, will sell for 1195 with BorgWarner S366, must be noted that the turbocharger has a tad bit too much end play no damage to wheels or housings just want to be 100% up front, would recommend sending out to have 360 Thrust installed. Both turbocharger and kit have less then 10,000 miles and less then 3 months old. Please let me know if you have any questions Thanks, Andrew.
Apcdiesel
Fort Myers Fl
SC Parrish, you are correct it is 66/73/.91 Divided T4 flange. I would like to sell the kit first and then we can talk about separating just the turbo. Thanks, Andrew.
Apcdiesel
Fort Myers Fl
Sale was pending but fell through, turbo kit is set up to use your factory or aftermarket downpipe, it does not come with a downpipe. We did not purchase this kit new, the pedestal is stamp D.E. Diesel
Powerstroke Man 6.4
I did a quick search on Google and this came up
https://www.facebook.com/profile.php?id=132451883627&_rdr
Most likely where this kit came from originally? Says they specialize in turbos etc Doesn't look like they have anymore than that on this company/kit.
08Monster
Does anyone know what it would take a mount an S472 on this? Just new piping?
Nick284
Buffalo NY
you would need a T-4 housing, which it probly is on the 72, guessing. and a new down pipe, and air charge pipe. i looked into doing it before...
08strokr
Leesburg, VA
I went from a 66 to a 72 and you have to change downpipe, hot side pipe, intake, and I had to redo my drain line to make it fit...you are better off buying a kit meant for a 72.
