6 Inches to Leveled
ahbennett4
I currently am lifted on 37s with 6 inches of lift. I bought the truck this way and DO NOT have any stock parts. I got ahold of some F350 XLT 4x4 coil springs however, what else will I need for stock. Order a set of 1.5 inch pucks of eBay. I believe I need a stock pitman arm, but what about adjustable trac bar and the bracket itself.
I believe the bracket looks to drop the bar, will I need a stock replacement if there is one? Ford part number?
Thanks in advance.
Just ordered 22 BMFs with Toyo 35s
08Monster
Pit man arm, sway bar linkage, track bar drop, shocks, and I few other things I remember installing. Quite a bit actually.
ahbennett4
Got the shocks covered. Sway bar links just look like threaded extentions but ill check into it. Where did y get your parts? Im having a hard time find the stock OEM trac bar bracket.
08Monster
I meant things I installed for my lift. I have all the stock parts lying in my shop, but I might go back down some day so I plan on keeping them
