there is a couple guys on here using them with no issues, I think the biggest deal was using oem manifold bolts, throw the ones that come with them in the trash
billy is using them gntcx or whatever he is lol.
no luck with their exh manifolds here...
an employee put one on his 2002 model...cracked same day..
had it warrantied...reinstalled...cracked same day...
Motorcraft installed and running fine for months now.
Same exact thing happened to us.no luck with their exh manifolds here...
You don't like me anymore
Back on track....I have 14K on the Dorman passenger side manifold but the exhaust manifold bolts came from Int'l.
Billy T.
[email protected]
I have and do use some dorman stuff, but agreed, even 10yrs ago their stuff was much better.
I have used probably a dozen sets of their 7.3 up-pipes and they have been fine. Lots of random things, such as, wheel studs, some sensors, etc.. have been ok.
However, my concern is they won't be cast heavy enough and want to warp from heat. In which case, I would be pissed I chanced it. Something a little more accessible I don't mind to give a try, but in this case, not so much.
I've used up most of my good oem manifolds or it wouldn't even be a ?. This particular engine even needs at least 1 of the valve covers from rust. :doh:
The salt is another concern. If they don't warp from heat, but still not heavy enough, then the salt will kill them in a few years. I'm just guessing here, I've never even had one in my hands.
