7.3 HELP!
Dieselcrazy93
Colusa California
My kids 01 7.3 ran rough and bucked for 30 seconds and just shut off. She had someone throw some parts at it like ipr, icp, and cps. I finally freed up at work and winched it on the trailer and put it in my shop. Truck was a no start, no smoke. Hooked up my Solus edge and found a laundry list of injector codes and failed IDM CODES. Unplugged valve cover connector and found melted plug and harness on right bank. Replaced valve cover harness and pigtail. Replaced IDM.
Truck starts and runs now but has persistent p1267 code. Ohmed our harness from IDM all the way to the injector plug and was good. Ohmed all injectors and they all ohm 2.9 except for #7 which was .5. Any ideas??? Thanks!
Dieselcrazy93
Colusa California
Thanks for the reply! I did not use ford. Bought aftermarket against my better judgement. When I went to the local dealer for the IDM and harness they said the IDM was backordered with no estimated fill date. So I bought the harness and IDM online.
