7.3 injector leaking oil??
superstroker99
edenton, N.C.
I just built my motor ran it about a week it ran great. cut off going to work tuseday.. got it to the shop put my scanner on it. Had 91PSI on the icp. Put air on the system sounded like a injecor o ring no problem pulled all put new ring on AGAIN and still no start. Build to about 320 and stops. can haze the intake with break clean and spin it fast enough to start and run idle duty cycle is about 13-18% at 1000-1200 psi. BUT i have oil runnin through my exhaust. Could this come from an intrenal injector problem? Im running 350/200 from full force
