7.3 motors,6.0 motor and alot of parts
RHCDIESEL
Imported Yankee to the south
i will take trades, some stuff im looking for is tonneau cover, train horns, 58v ficm, injector cores, amp power steps for 06 cc 155 cc inj, powermax,im sure theres more stuff i would trade for just not remembering at this moment!
2000-7.3 147k miles no injectors,icp sensor, or hpop&ipr. Dont really know whats wrong with it we did a compression test and a valve was stuck open so we didnt finish the test, the other cyl we did test had close to 400 psi while the one with valve stuck was 210. $600 firm + shipping or you can pick up
1997-7.3 49k original miles has everything on it including injectors hpop turbo , the only thing i know about the engine is that it had water and oil mixing and when we took the valve cover off we noticed that a freeze plug was missing so we put a new freeze plug in it. since there was mixing going on i would recommend new rod and main bearings i took one off and its not too bad but i would fix while engine was easy to access! $1500 +shipping
2001-7.3 160k miles has blowby on a few cyl, does not have inj turbo hpop. does have plenums turbo pedestal valve covers and gaskets they are just taken off. 400$
97-7.3 200k compression low on few cyl no inj or turbo $400
2006-6.0 150k(20k since machine work) ran good in my truck until i blew the black onyx head gaskets. The heads have been machined down flat and preassure tested, block was machined and so were pistons to make sure nothing would touch and keep everything in tolerances.crankshaft will come with it but the dowel in the tone wheel is broke. ill send arp studs with it also. along with all the misc pieces that come with the engine minus injectors, hpop, and front cover!$1800
RHCDIESEL
I do not have that 01 anymore i just got rid of it, but i do have another 01 that has all parts taken off to do a late 99 coversion for a 97 and no inj. Im not sure if it has forged rods or not ill have to check into that.It has fuel bowl, ic pipes, front cover,pump and bracket. i would take 400 + shipping for all of that or 200 + shipping without ic pipes and bracket!
shorty2tall
Cheyenne, WY
ok ya if u could see if it has forged rods or PMR's. how many miles on it? and did it run or what was wrong with it?
what about that 1997-7.3?
also do u have any that are complete?
shorty2tall
Cheyenne, WY
Ok. Find out if it has pmr's then if it doesn't we can figure out shipping and what bracket is it u said you'd sell it with out?
