oldbluef250
Everything has about 100 miles on it unless otherwises stated. I've decided to get a newer truck instead of building a puller. Everything is + shipping
350/200 hybrids. They were gone through by casserly before I put them in, but I will send them back to him and have him go through them again before they are sent to you. $2000
SRP1 pump- $700 NO CORE NEEDED
International Bellowed up pipes. $350
ZF5 Valair Dual disc sintered iron clutch. Comes with flywheel and throw out bearing - $1400
ZF5 transmission and superduty transfer case w/ driveshafts - shifted fine for the little bit I had it. It would pop out of reverse sometimes. I just changed the fluid on it. New slave cylinder. If your looking to swap in a manual into a extended cab short box superduty, this would be perfect. It would even come with front and rear driveshafts that I had to have made. $1400
If you wanted the clutch and trans with everything, I also have the pedal assembly with the master cylinder I'll throw in.
Complete electric fuel system with fuel lab pump and tsd sump. Napa filter bases with baldwin filters. Parker hose. Braided stainless line going up to the valley and going to the back of each head. Aeromotive regulator. The whole fuel tank would go with it since it has the hole in the bottom of it. local pick up only. $1000
S475 Brand new never used, built by river city diesel 2.6 cover tapped for reducer, 75mm wheel , 96/88 exhaust , 1.32 ar , t4 foot. $950
Precision 46mm wastegate. NIB $250
7.3 short block. This is the motor rpm inc had in his van. H-11 headstuds torqued twice. comp 910's. Smith bros push rods. Exhaust ported heads. Find more info here. I put the push rods in once I got it. $1700.
Forged rod longblock, H-11's, 910's - PowerStrokeNation
Complete 2002 Extended cab short box minus the things listed above. So it would be pretty much everything except the motor and transmission. I just got the rust fixed in may. Interior is in pretty good shape. Sound deadener installed on the floor a few weeks ago. Plastic bed liner. New ball joints, tie rod ends, and u-joints installed in May. 305/70/16 cooper stt tire. 65% tread. Would make a good cummins conversion truck. Clean Title. $7,000
Pics will be added later. 715-896-3977
