7.3 Ported Heads, 185lb springs, Filled block, bottom end girdle kit
NRHX2009
Elizabethville, PA
All parts have about 5-6k on them.
I have a set of Ported and polished 7.3L heads. 185lb beehive springs. Head porting by Carson Stauffer Diesel. 3k into them, $2000
7.3L Block that was cryo'd and heat treated. .20 over bore.
No cracks. Had a piston crack in one cylinder, but cylinders can be honed w/o boring and easily be saved. small scratch in one cylinder.
Hardblock fill is about 2" from deck height. Ran on the street w/ electric fans and had no problem with overheating issues. $400
Full bottom end girdle kit. Includes 3/4" thick aluminum girdle, (ties into mains and pan rail) spacer, main studs. Torque twice. Modded oil pickup tube, and modded oil pan to work with spacer. Comes with extra long oil pan rail studs also. $1500
All prices are plus shipping. I get very good rates though UPS so let me know. Block will go freight, Heads should go freight to assure no damage while shipping.
PM or call 717-919-7423
gol dammit! i need to get back to work so when this chit pops up i can snatch it up! being laid off sucks.
neverkickn
AR
Did Carson do the block work? How much port on the heads, just a mild cleanup/street p&p or more?
NRHX2009
Elizabethville, PA
Carson did the block filling yes. I forgot to add that this block has fire ring grooves. I did a 50/50 on the block and heads so unless bought as a pair, the groves will need cut deeper.
NRHX2009
Elizabethville, PA
I know there was about 5lbs of material on the workbench after the heads were ported, so I am asuming it was a pretty decent port and polish job.
Viking
Minnesota
Congrats on the sale
Just make sure you post a build thread or videos when its all together and running!
PSDEng
Bellefonte, PA
:D Thanks guys I'm really looking forward to this all coming together. I'll keep everyone posted on how it's going!
BTW James is a great guy to work with, stand up guy and he knows his stuff.
whs^^^ ive talked with him and bought a part for a turbo from him! great to deal with and talk to...
NRHX2009
Elizabethville, PA
And no one asked why I was selling all this yet???
Converting over to the darkside for the puller... should be done in 2 months or so.
1100+ is the goal :)
i hate you. you suck! dont do business with this guy! some things are better left alone!!
lol... jokin man. good luck with your endeavors.. but you still suck, quitter!! lol
