7.3 Precision drop in turbo, external tial gate
rpm-inc
Ideal for high pressure turbo in compound system. Precision drop in turbo with billet wheel. Correct 1.15 housing machined for tial 44mm wastegate.
Turbo has probably 10k miles on it.
Turbo, no exhaust housing. (any stock 7.3 SD housing works)-1000
Turbo with modified coated exhaust housing-1500
Turbo with modified coated exhaust housing and the V44 gate-1750
Will sell items below if the turbo sells first.
Used international up pipes-200
EBV delete pedestal-60
Or 1900 for the turbo, housing, gate, up pipes, and pedestal
Free superduty exhaust manifolds if needed. Will also throw in a van intake y.
rpm-inc
bad12jr
Any pics in the charger? Ball bearing?
Sent from my NookColor using Tapatalk 2
jaybuller
Nice! To bad I just bought a turbo!,, but if you sell the turbo separate to someone ill buy the bellowed uppipes from you. Thanks and good luck looks like a nice setup!
rpm-inc
Its journal bearing. Just took these.
Has the van adapter on it. High flow outlet in first pic included for asking price.
Hard to get a good pic of the billet wheel. The smaller fins behind the big ones are making the shadow.
