7.3L Engine Parts (Worth anything?)
Black 02
Woodland, WA
As some of you know, my PMR engine took a crap awhile back.
I have another complete core engine that I'm using for a rebuild, but was wondering if any of these parts off of the original engine are worth anything.
The block is scrap, but I don't want to scrap something if there is value to it. Not trying to get rich. Just don't want to scrap things that aren't made anymore either.
Any help is appreciated.
Crank
Heads
Cam
Rocker Arms
Main Caps
SD Fuel Bowl
SD intercooler pipes
Stock SD turbo with EBP pedestal
Stock SD intake plenums.
If anyone would like this stuff, let me know. If not interested, just letting me know if it's worth keeping would be great.
Thanks in advanvce
JLDickmon
not really..
might want to save the heads (assuming you have another set)..
other than that, is's pretty much paperweight
davey99ps
Waterford WI
Stock sd intake plenums (if they're 3") are worth $50-65, the intercooler pipes are also worth some $. Personally, if the heads aren't trashed I'd hold on to them an down the road have them ported an polished depending on what your goals are for the truck. As far as the rest of the stuff, it's not really worth much unless you happen to find that 1 person that happens to need it.
Binder man
The fuel bowl is worth a litttle change. So is the crank. I think I usually sell used bowls for 100-125 depending if the FPR is still on it.
CSIPSD
Bend, OR
Crank $100
Heads $100-200 assuming no cracks
Cam $75-$100
Rocker Arms
Main Caps
SD Fuel Bowl $100
SD intercooler pipes $100
Stock SD turbo with EBP pedestal $200
Stock SD intake plenums. $30-$50
Thanks in advanvce
I would be more then willing to take the IC pipes off your hands...for $25 bucks or so...
Arisley
Arlington, Texas
I would hang onto the stuff, you will find someone on here needing it sooner or later. If you have the room to store it that is.
POWER-STRUCK
Indiana
SD Fuel Bowl
these parts would be the things that i would try to talk you out of if i were local!!!
CSIPSD
Bend, OR
Thats why I have a box of BS parts... So when someone needs something thats really not worth much, I can rape them and send it to them...
Wait...
Most times I just send it for free, because it cost me nothing.
Expensive **** I'll sell, HPOP, IDM's PCM's... but little **** just goes in the parts bucket.
nwpastroker
Northewestern Pennsylvania
If you plan on building a fairly high hp engine might want to keep rockers for spares, seen a few threads on here of people snapping rockers with higher boost, not any personal experience, just a thought
Black 02
Woodland, WA
Yeah, I was thinking of keeping a few rockers. One already broke when the rod broke, so I don't have a full set anyway.
