7.3L Issue
Worstenemy453
Fredericksburg, Va
Truck will start fine and run. 2002 7.3. Truck has 180K miles. Completely stock.
When the truck gets hot, it wont start anymore. Will start fine when the motor is cold. We let it run for a few, shut it down and it wouldnt fire back up.
Replaced the CPS and still have the same issue.
Thinking Hpop or IPR.
Any input or anything ?
Tom S
I think you are on the right track. Time to watch ICP at hot start up.
neverkickn
AR
It's all guessing without numbers. Have you been into the hpos recently?
Jake
TEXAS
Injector o rings. You can pull the valve covers, and crank it I bet you will have oil coming out around an injector. My 97 did this last year just like that.
