7.3l upgrade 95-02
Xtra
Hey guys I've got a reg cab f250 bolt action, with a tired 7.3 int it.(420km) And I have a recently written off 2002 7.3l with fresh injectors and was humming like a top when I smashed her up. Front end damage unfortunately. So I was thinking about swapping them up and tossing the 02 7.3l in the 95. It would run me close to 1500 in parts unless I can use the rad out of the 95 and the inter cooler Mabey from a 6.0l, I might have one out back lol. So would I need to rewire the engine compartment for the new 7.3l with the comp. or? And a auto to stick? What are your guys thoughts?
Magnum PD
VA
I would use both computers out of the 02 in the 95 even wiring harness.
ghohouston
Lewisville,Texas
Just swap motor from sd to obs... Use obs engine harness, you will have to change a couple of sensors, and you will either need to use the obs injectors, or get a chip to run the split shot injectors in the obs.
superpsd
Missouri
Just wire in the SD PCM into the obs harness. It has been brought up and covered a few times. There are write ups about it as well. Or just swap in the complete harness. Then don't even have to tune it if you don't want.
