72mm S300 OBS KIT
Derek@Vision Diesel
Canby, OR
Turbo: 72mm billet wheel, s300 with 19cm exhaust housing.
Mount: T4i with all hardware included and the turbo drain and feed lines. Stainless Steel up-pipes with new bolts that connect to manifold.
Irate Diesel's mount kit!
All you need is a downpipe and to adapt your IC pipes to fit.
$1500 shipped and ready to install. Turbo is in great shape with low miles on rebuild.
PM ME
Derek@Vision Diesel
Canby, OR
estrada5.9
What is the turbine wheel size?
This is what I am looking for minus the T4i but can be dealt with once I go bigger ha!
New to the PSD game coming from a 12v and still have a 03 5.9 CR.
I have a 97 with, studs, SRP1, 250/50 (soon to be 200%'s) and a intercooler, fuel, tranny and a 38r.
How would that turbo do for me? flow, spool, durability etc?
I was looking at a 72/83/1.0 T4 but then would have to get all the extra's.
Derek@Vision Diesel
Canby, OR
This would be perfect for you id say. Ask Beans Diesel Performance about it. Bean claims its a 550-600hp turbo, they said the one reason they stopped producing it was because of surging. Let me tell you ive never had it surge on me!
Turbine wheel is 73 i think.... it has a 19cm housing thats about all i know without asking Bean more about it.
lsmith33
Katy, TX
im not sure. i kno a d66 is drop in for an e99. i was jus curious if this would work because its for an obs, this might be an option if it'll work
Derek@Vision Diesel
Canby, OR
Well you would be replacing the stock turbo pedistal and up-pipes with this kit. So you need to make sure your manifolds are the same as an OBS, if they are it will work flawlessly
