SaNnDnSurF
Im wanting to go bigger with my lift, thinking about running a 2.5" Coil spacer up front and an add- a leaf in the rear am I missing anything else? Dont wanna run into problems thanks.
Ok so Im gonna do a 2" spacer in the front whats the best way to level the rear out then? add a leaf or another block and what size?
Make sure your shocks have enough travel in them for the extra inches you want to add. You don't want to have them maxed out and not be able to rebound properly. And you will probably have to shim your carrier bearing down a little more... 1/4in shim for every inch up in height give or take.
